why subvi pop up automatically?
Hi, I have a problem here. I was using the subvi "color table generator" from the Labview example "Creat Intgraph color table". But this subvi keeps pop open once it's
called. I checked the subvi node, none of the checkboxes was selected. I couldn't find where else should I change the set up. Can anyone help me with this? Thank you very much.
(3,235 Views)
The VI is set to pop-up in VI Properties>Window Appearance>Customize. I don't see where that is a problem though. It's not useable unless you have it pop-up.
(3,226 Views)
Hi Vzn,
Just as Dennis has stated, to control whether or not the front panel of a subVI pops up when called in LabVIEW is found in the VI properties. There is a great knowledge-base article that discusses this property in more detail. Please take a look at it and let us know if you have any questions. I hope this helps answer your question!
Carla
Applications Engineer
(3,199 Views)
Thank you very much. That helps a lot!
(3,189 Views)
