while loop problem
For repeating block diagram code i placed my code in a while loop...but
something is not clear for me :
1] It's possible to create a button on the front panel which pause/unpause
the vi when pressed ?
2] If i use this vi as a sub vi when i call it from a button in the
principal vi it runs continuously until i press a button .Things seem to
work but problems grow when i want this subvi to pass a result to a
principal vi.indicator.If i use a subvi without while loop there are no
problem but when i use my subvi with a while structure after i close it no
value return to the principal vi's indicator...what's wrong??
Thanks a lot in advance
Horackz
(3,006 Views)
1) About "Pause" button: there is not built-in pause button in LabVIEW. You must write code yourself. Usually you can write empty while loop that just waits until button is pressed.
2) I don't understand your problem. Can you post your vi or image of your diagram. It will be more easy to help you.
Nadav.
(3,006 Views)
As far as the subVI issue, your problem could be that the while loop is running continuously when called from the top-level VI and that's why it returns nothing. You will need a way to stop the while loop in the lower-level VI so that you can stop it from your top-level VI. The best way is to have a button input which stops your while loop (assuming you have already done this in your while loop).
J.R. Allen
(3,006 Views)
