does NI-IMAQ 1394 Driver support LabVIEW
I can not find and change in the Labview VIs,
and I only found the examples for C.
anyone knows?
(2,712 Views)
Young,
Make sure that you have LabVIEW installed in the default directory, which version of LabVIEW do you have?, then when you install IMAQ 1394 be sure to select the support files for LabVIEW. If you have other versions of LabVIEW or previously had other versions of LabVIEW then you may want to check those directories to see if the driver installed the VIs in there, instead of the version that you are carrying right now. The VIs are installed under C:\Program Files\National Instruments\LabVIEW xx\vi.lib\imaq1394.llb you may even want to run a search on your disk for this file "imaq1394.llb".
Which operating system are you running? If after following this suggestions you cannot still find the LabVIEW VIs then give us a call, www.ni.com/ask, when version 1.0 of t
he driver came up LabVIEW 6.1 wasn't released yet, so you may have a folder created instead even though you have 6.1. Please give us a call after you have followed the above recommendations so we can help you.
Nestor Sanchez
IMAQ/Motion Support
Nestor
(2,712 Views)
