when boolean is change , i want add value
I want to add +1 to the variable value when the boolean changes.
for example like boolean ( off -> on ) just one time i want add +1 at my value
( on -> off) or ( off -> on) when this change , one time add + 1
thanks help me
i saw some about for it ( like use "feedback node" or " shift " )
but i dont know how use for my problem
(1,444 Views)
Hi morong,
@morong wrote:
i saw some about for it ( like use "feedback node" or " shift " ) but i dont know how use for my problem
Did you notice those "Training resources" offered at the top of the LabVIEW board?
It seems you could use them…
Read the help for the PtByPt-BooleanCrossing function.
Then you just need to add a select node and a shift register in your loop…
(1,431 Views)
As has been said, the training resources are a good start. Show us what you tried and where you got stuck!
If you already "saw" a solution somewhere here, it would help if you give us the link so we can tell you if it is a reasonable solution.  There are plenty of old discussions with examples, because this is a recurring beginner problem. (For example does this make sense to you?)
(1,398 Views)
It's also relevant what this 'Boolean' is.
Is it a Boolean control? Or a digital DAQ signal?
(1,374 Views)
