what type of function is this?
Hi..
I am new to Labview, can anyone help to tell me, what time of function is the icon that i attached?
Is there any ways to get icons name by viewing all the icon at one place?
Thank you very much
(2,880 Views)
You should use the context help while hovering the mouse pointer above the elements you want to learn about.
Also, you should work through online trainings material or attend a LV class from National Instruments.
Norbert
Norbert
Expert: Geometry
(2,869 Views)
Thank you for your respond.. i know context help is very useful and i always used that.. the problem is the icon that I attached was found in online tutorial.. and without any description.. so, i wonder if anyone knows what is the attached icon function name
(2,850 Views)
To give a specific answer: It is the Bundle function which creates a cluster dynamically by bundling (in case of your screenshot) three different data types together.
Norbert
Expert: Geometry
(2,842 Views)
Accepted by topic author MASuhaimi
(2,814 Views)
(2,807 Views)
