what does analog output do after output
Hi all,
  I have a question about the behavior of the analog output on a single AO channel. If I write a single voltage (1.2volt) to an AO channel and keep the operation lasting for 3ms (using delay). I wonder after 3ms, what state will that AO channel be? Will it maintain the same voltage or will be reset (to zero) or whatever?
(2,726 Views)
An Analog Output will hold the last value until the device is reset or a new value is written.  It is advisable to set the AO channels to 0 when you are done with them.
(2,720 Views)
It will remain at the last output value until the device is reset or something else needs the AO resources
"Should be" isn't "Is" -Jay
(2,719 Views)
Accepted by PKIM
just to piggy back off of what was said....
(2,710 Views)
