07-28-2009 08:43 AM
Solved! Go to Solution.
07-28-2009 09:14 AM
Did you ever think about doing a search?
07-28-2009 10:36 AM
It is going to be very difficult to find the exact code you are looking for.
Even if you find an ECG example, it may use different hardware than you.
It would be better for you to try to understand the code that you find, so you can modify it as needed.
07-28-2009 12:15 PM - edited 07-28-2009 12:16 PM
First of all , for acquiring the ECG singnals , you need to get an ECG machine ,at least a single lead, with an analog output. Then you have to get NI DAQmx kit from the NI dealers. After that you have to think about the codings required for analysing the ECG from your pc using Labview. If you have the first two hardwares, let me know , i guess i can help you...
Nitzy...
All India Institute of Medical Sciences
New Delhi
07-28-2009 12:48 PM
Please visit our Biomedical User Group here: http://decibel.ni.com/content/groups/biomedical-user-group
There are a number of articles about the proper signal conditioning needed to amplify and record ECG signals as well as articles on processing ECG signals to extract features.
Steve
07-28-2009 12:56 PM
Unity wrote:First of all , for acquiring the EGG signals , you need to get an EGG machine ,at least a single lead, with an analog output. Then you have to get IN Addax kit from the NI dealers. After that you have to think about the codings required for analysing the ECG from your pc using Labview. If you have the first two hardwares, let me know , i guess i can help you...
Nitzy...
New Delhi
It is not so hard to build your own EGG circuit, as a do it your self project. If you use a laptop computer not connected to the mains, use safety resistors, and power the circuit with battery's. Then the risk of electrical shock is very small. If you use proper commercial electrodes your project may be successful. But you can not use use this setup for any medical comercial, or even demonstration purpose. Even thinking about it is a bad idea....
07-28-2009 02:08 PM
Coq Rouge wrote:...It is not so hard to build your own EGG circuit, as a do it your self project. If you use a laptop computer not connected to the mains, use safety resistors, and power the circuit with battery's. Then the risk of electrical shock is very small. If you use proper commercial electrodes your project may be successful. But you can not use use this setup for any medical comercial, or even demonstration purpose. Even thinking about it is a bad idea....
Somehow I get the felling that warning has a scar to go with it.
Ben
07-28-2009 02:32 PM
Ben wrote:Somehow I get the felling that warning has a scar to go with it.
Ben
Did I say something wrong? Since I get the
07-28-2009 02:45 PM
Ben
Oh NO!
Far from it. I found your post entertaining and that emoticon choice represented my memory of my first (unfortunately not my last) electrical scar.
Ben
07-28-2009 03:11 PM
Oh I see. Sorry since my native tongue is not English I sometimes get the fine details of Enlist language (or emotions) wrong, my fault. Well I have get some electrical shock in my life but never a scare. But I have a small scare slightly above my eyebrow. I was 15 and experimenting on implementing current limiting with a LM723 chip on breadboard . It ended with the LM723 chip exploding in my face. In those day a breadboard was quite expensive so I was more concerned about breadboard damage, not that I could have lost my eye
I wrote "Even thinking about it is a bad idea...." Since I work with medical systems. And doing medical measurements outside "the house" without all necessary and unnecessary approvals/documents is quite risky
