webdav PROPFIND .NET
Due to unreliability of the FTP server on RT target, I want to change the way to get or put files on the RT controllers using WebDAV.
The main problem is that I'm using .NET langages (C#) to get connected to the RT.
I tried to communicate with the webdav server using LabVIEW and it works fine but because my application is written in C#, I have to translate it.
Everything works fine to get, put, create and remove file or folder but I would like to get information about the files and folders.
My problem is that I want to use the same command than the Directory Listing VI as shown below.
There are little differences between the LabVIEW way to get connected and C# way.
My question is which WEBDAV command is used in Directory Listing VI ?
Best Regards,
CFOE
Message 1 of 1
(3,254 Views)
