fpga
I am trying to read the actual temperature using NI9211 @compactRIO using FPGA in celcius.Tried few options but the temperature is coming in -ve. Any help
(3,491 Views)
Vishal,
It seems like your FPGA TEMPERATURE.vi did not attach correctly (I opened up to a blank VI).  It might help to attach that again so we can see what you are doing.
In the project you should just need to right click your module and select properties.  In the menu that comes up, make sure you have Calibration Mode set to Calibrated.  If you are still not seeing the readings you are expecting can you show us what you are receiving and how you have your hardware set up?
(3,453 Views)
I am getting -243 celcius reading
(3,432 Views)
