web publishing
I am presently working on remote laboratory.
I have published some labview Vi's using remote panel (web publishing tool). They are not accessible from the internet outside my local network . I believe this is because my Host PC has a private IP address. Does anyone have an idea how i can make this published VI's accessible on the internet.
(3,778 Views)
You need to setup the correct port-forwarding options on the router that connects you to the internet.
This should be explained in the documentation of the router, if you are in a corporate system you should contact your IT administrators.
The port you need to forward is port 80.
Ton
My LabVIEW Ideas
(3,758 Views)
What is your lv version?
(3,756 Views)
LabVIEW version 8.6
(3,738 Views)
My IT guy said Port 80 is already being used, and that i can only use ports 8084-8088.  Is there some reason labview wont work with these ports?
(3,399 Views)
