how can I map an image (JPEG) from the SQL database image string
I saved the image into SQL database, see attachment (SaveImage2SQLDB.rar), while I have some trouble to retrieve the image. I also attached the vi which I used to convert the string to image. The string already has a value I obtained from the database. Can anyone tell me the reason why it didn't work.
Thanks in advance.
Jane
LabVIEW 2012, VDM 2012
(3,943 Views)
Hi Jane,
What exactly isn't happening correctly?  The conversion or the retrieval?
This discussion forum may be of some use: http://forums.ni.com/t5/LabVIEW/image-from-compressed-string/m-p/2207894
Matt S.
Industrial Communications Product Support Engineer
(3,916 Views)
I used unflatten string function to try to get the image, but there is an error code. Can you open and run my attached <convertstring2image.vi>? The input HEX string is the one I retrieved from the SQL database.
(3,904 Views)
Hi Jane,
I'm not sure why your error is occurring, but I found an example on how to do what you're attempting to accomplish, please this link: http://forums.ni.com/t5/LabVIEW/imaq-string-to-image/td-p/1100298
Thanks!
Matt S.
(3,887 Views)
To save the image to the SQL database <image> type data, I have to change the string format. In the save image vi, you can find this. The example you mentioned actually didn't convert the string.
Jane
(3,876 Views)
I don't have IMAQ right now but it looks like you convert to a string and then do some other conversion with a subVI that you call flatten to string. Its not the same as the LabVIEW of that name. I would suggest you look again at the first link you were given and directly convert the image with the real flatten to string and back to image with the unflatten function.
(3,871 Views)
