way to test an empty class
i wonder to know wich way can i use to test if an object contained by another exist or not
Best regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,263 Views)
What do you mean by exist or not?
What do you want to do?
Could you give us more details about your question?
Regards, Samuel G.
Samuel G. | GEMESIS
Certified LabVIEW Architect
Certified TestStand Developer
GEMESIS.EU
(3,249 Views)
I mean for example if  i have a car class including  or not (optional) a radio set
I thought that creating the car object not involve creating the radio but i tested  it is false
a default radio is present.  So an object for what i tested is never null .
How to manage optionals objects into others ?  example of car with options : radio set, gps, air bag, tv ...
may be the create by ref is needed in this case ?  or maybe creating child class of options with the default class , no radio, no gps, no air bag ...  ?
Best regards
Tinnitus
(3,243 Views)
You can create a Boolean in your option (radio set, gps, air bag, tv). When the car is created, the Boolean are instantiate. Then you could create a method to check is the Boolean ok or not.
Regards Samuel G.
Samuel G. | GEMESIS
GEMESIS.EU
(3,240 Views)
