array even odd
Hi all
I have a question that is not how to solve. Well, I have an array of complex numbers and what I would like to separate the one hand the values ​​that correspond to the pair of array indices and on the other, which correspond to the odd indices to be plotted after each part. Any idea how to do it?
Thanks!
(3,825 Views)
If you dont mind, can you explain it a bit more..may be an example..
Nitzz
(3,824 Views)
If I understand your question correctly you can just use the "Decimate 1D Array" function.
(3,821 Views)
