waveform scalar limit comparison
Hi all,
I m using the waveform scalar limit comparison to test if values are
greater than a particular value. Im aware that the output of this vi
is an array of two waveform data.
1. The original set of values
2. The set of values that satisfy the greater than limit comparison.
I need to access the second set of values and delete these values from
the original array.
I have no idea how to extract these values only. Any ideas?
Thanks and regards.
(2,611 Views)
Hi Prakruthi,
      Not 100% sure I understand, though, maybe this VI will work for you.
Cheers! Smiley Happy
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(2,597 Views)
