Formula Node (Numeric Comparision by using AND, OR functions)
Dear All,
I want to compare my input if it is in the range of/between 0.00 and 0.5 it should return/output 0.5, how i can do this in Formula Node.
e.g
If (x>=0 and X<=0.5)
y=05;
if (x>0.5 and x<=1)
y=1;
if (x>1  and x<=2)
y=2;
(2,817 Views)
Hello M.
As long as your logic does not get much longer I would recommend a conditional evaluation like
y =
(x>=0.0 && x<=0.5) ? 0.5 :
(x>0.5 && x<=1.0) ? 1.0 :
(x>1.0 && x<=2.0) ? 2.0 : -1;
I hope you like it, Guenter
(2,810 Views)
Thanks Guenter,
Its first time that i Got so accurate response from NI. But only thing that i want to know was how i can use OR function like AND (&&) you already explained in a well maner.
(2,795 Views)
