waveform data time stamp data formate
I wrote wavform data to file using write to measurement express VI
The data is like this,10/01/2012 11:32:55.756 AM
But I prefer to have no am, pm and year date.   and the formate should like this.  15:32:56.756 How can I achieve this ?
(3,249 Views)
I'm not sure if you can, using that VI. That is one of the drawbacks to express VIs...you're limited to what NI gives you. If you write your data to a text file, you can first format the time string using this VI
(3,248 Views)
But for the vi you said, it seems can not give value such as 11:35:25
I need the decimal point of second
(3,241 Views)
Accepted by dragon-long
Yes you can; the page I linked to specifically says the following:
"%<digit>u (fractional seconds with <digit> precision)"
You'd do %H:%M:%S%3u
note: there is no decimal point needed between the %S and %3u because the %3u (i.e. fractional seconds) will add the decimal point in for you.
(3,234 Views)
(3,204 Views)
