waveform chart ploting problem
Hi
I have this a problem in this example which i use 2 waveforms to be ploted in one waveform chart
the problem is that it start plotting at the far right..
how can i make it start plotting at the left??
thanx
(3,578 Views)
Hi
Remove the waveform generation and all the dynamic data vis. Just wire the two double values to a bundle function. The output of the bundle function can then be wired to the graph. You will also have to modify the initialisation of the graph.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,573 Views)
this is great it works Smiley Happy
thanx alot
(3,568 Views)
By the way - you want to display 10 points. If you set the scale-range e.g. 10 - 20 results in displaying 11 points.
Using LV8.0
(3,565 Views)
