Message Edited by Jarrod S. on 05-12-2006 10:29 AM
Hi jarrod,
first your example is good and i don't think that the problem is in your vi!!!.
let me explain what i'm doing :
i know that in dos (run->cmd) i can see in the end of the string the ^G and then enter , so the barcode is working good.
try to press[ctrl+g] in dos mode the computer will beep after the enter,but in labview it's[i think] asurtcut and when i try to insert the barcode
it's doing something(change the working mode from edit mode to run mode) maybe we need to disable the surtcut menu and then try it.?
do you know how to disable this surtcut?(it's not in the vi propertis, i try it ...not working).
regards
eyal.
Message Edited by TonP on 05-16-2006 07:59 AM
