want to merge three array
Hello All,
 I have three array as follows:
Array one( 2, 3, 5 ,1, 0, 4) values
Array two(00, 01, 03, 04 , 02, 05) values
Array three( Name1, Name2, Name3, Name4, Name5 , Name6) Values
Now i have to merge these three array in one array as follows:
Array(2_00_NAME1, 3_01_Name2, 5_03_Name3...... and so on)
Can anyone help me with this???? I dont know how to merge this as a one ????
If anyone can help i would be very glad...
Thanks in advance..
Pals
(2,827 Views)
@pals wrote:
Hello All,
Thanks in advance..
Pals
What format is Array one, and Array two in. You can not mix a numerical array with a string array. However it is no problem in converting a numerical value to a string. Or a numerical array to string array. Can you post your coding attempt even if it is not working?
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,819 Views)
I am attaching the program, but its totally wrong.
thanks so much...
pals
(2,814 Views)
Accepted by Sim5
Not sure just what it is you want, but this might be a start.
Omar
(2,803 Views)
Hi Omar,
I did very little modification and yes i am gatting the correct result...
Thanks so much...
I am attaching the thing which i wanted...
Thanks so much....
pals
(2,794 Views)
