wake up computer with labview under MAC OS X
Hi all
My program is running and after a while the monitor shut down
Now my program get a event that the monitor has to be awake up
Is there a funktion with that I can wake up the monitor or a screen saver
Any help
Jürgen
(2,655 Views)
Jurgen,
I have not tried it, but look under Communications>>AppleEvent. You should be able to send an AppleEvent command to the Finder or to the screen saver application to do what you want. Also, make sure the computer itself is not going into sleep mode.
Lynn
(2,643 Views)
One possibility is to set the mouseposition to other points. It doesn't work in windows but you can try it with your Mac but I have no experience with Mac/Apple. Its only an idea.
Good Luck!
Markus Weigl
(2,633 Views)
