Memory allocation in external dll functions
I just coded a very little dll that adds a function to a Labview component. The function is called and the job is done, however I am experiencing memory issues :
- first when the .vi is loaded 80Mo of memory is used (whereas the .dll size is 44Ko)
- then when the .vi is launched and additionnal amount of 180Mo is used
- at last when the function is exectuted the labview program freezes because of the memory allocation done in the function (DSSetHandleSize)
So I would need help to fix the strange extra memory usage from labview, and to find a solution to my function memory allocation.
Thank you for your time,
Pipo
(2,786 Views)
To respond to your request, I need more information :
1 - LabVIEW Version?
2 - You say "at last when the function is executed the LabVIEW program freezes because of the memory allocation done in the function (DSSetHandleSize)". Do you receive error message?
3 - Have you call your DLL with other program except LabVIEW?
4 - Your VI is simple one? Can you call DLL in simple one?
Can you please send me your DLL and your VI?
Best Regards,
Sanaa T
National Instruments France
Sanaa T.
(2,752 Views)
