wait a 'while loop' until new order
the VI added works OK. My doubt is that: How I do to execute in only 2 loops?
This VI should do, in the first loop, switch ON the led. Soon after, when the user wishes, stop the program (and switch OFF the led) in a second loop.
LV7.1 / Win XP
(3,651 Views)
Looks good to me and don't see the problem.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,641 Views)
There aren't any problem... but I want to optimize the VI: when I stop the program it has do XXXXXX loops. I want to do 2 loops: the first to switch ON and the second to switch OFF.
(3,634 Views)
Hi vicens,
you can do it like this...
(3,631 Views)
I would use an event structure. Modify as needed.
(Of course it seems a bit overkill to even use a while loop for exactly 2 iterations. If you know the numer of iterations beforehand, a FOR loop is usually more appropriate. Can you explain in a few sentences what the purpose of all this is? Maybe there is a much better solution :))
(3,609 Views)
