Contiguous Waveforms using an Oscilloscope
hello one and all, i am grabbing discrete waveforms from an oscilloscope. each waveform has approximately 5 periods at the frequency i am studying and there is a lot of noise that i want to filter. so i want to apply a IR notch filter to do this, however, those filters require prior waveforms for the frequency rejection. the waveforms are snapshots from the scope and so i get the error "20352: Current and previous waveforms are not contiguous." so how can i use FIR or IIR filters with my scope?
thanx in advance.
lucas
(3,478 Views)
That really depends upon what oscilloscope you are using.  Most modern oscilloscopes have the capability to continually stream data to a host computer.  Bandwidth is an issue, so board based scopes (like the NI ones Smiley Wink) will allow you to stream at higher acquisition speeds.  If you are using an NI scope, check out the example niScope EX Fetch Forever.vi.  IVI based scope APIs should use a similar mechanism.  I can't comment on GPIB/SCPI based scopes, since I have not used that API for years.
Let us know a few more specifics - scope model, acquisition rate, API used, etc. - and we can help you more.
(3,460 Views)
ok, i think i got it working nicely.  since i was grabbing discrete waveforms from the scope i had to create a waveform.  the waveform's dt was not to difficult, but the t0 between waveforms was a little tricky.  once i had that coded properly, the IIR filter works great.  i was afraid to go continuous on the scope because i didn't want a computation bottleneck somewhere causing the thing to crash.  thank you for the help.  lucas
(3,432 Views)
