wafer map plot
Hello yariv3G,
I made this by using a picture indicator and drawing lines and filled rectangles...
How to find the array bin: there should be a property of the indicator giving you the mouse position. From this you can calculate the array position. Yes, it involves some math 🙂
Message 11 of 13
(2,011 Views)
Post some sample data as a text file and the existing wafer map and we'll see what we can do for you.
Message 12 of 13
(2,004 Views)
Here is an example with the color box array. The color box array is intialized with the color white. Every other array cell is used to hold result data. You could use a cluster array that contains the cell location (row, column in color box array) for each datapoint in the wafer map.
Message 13 of 13
(1,987 Views)
