vlc player activeX
bonjour, je souhaite tester l'activeX de VLC player, mais
je suis bloqué dès le départ, Labview  n'exécute pas l'activeX
( insertion contenaire en face avant  -> choix de l'activeX VLC -> erreur ( pas de n° d'erreur Labview ))
( J'ai validé les activeX dans labview et lors de l'installation de VLC )
D'autres activeX fonctionnent parfaitement
Y a t il une précaution ou une manip particulière pour utiliser cet activeX
Merci
(4,054 Views)
Apologies, I'm mostly limited to one language.
The VLC ActiveX plugin exits with an "Unspecified error" when embedding it into the LV ActiveX container.  The VLC readme does say "Please note, that this code does not rely upon Microsoft MFC/ATL code, hence good compatibility is not guaranteed."
The best I've been able to do is embed the VLC plugin into a web page (as shown on the VLC site), then embed a Microsoft Web Browser object into a LV ActiveX container and call the web page from there.  This works, but really limits what properties you can affect on the object.
Good luck,
Joe Z.
(4,043 Views)
ok, i will test your solution,
but with delphi there is no problemes to use the VLC activeX
thank's
(4,036 Views)
