‎06-15-2006 11:33 AM
‎06-15-2006 05:30 PM
LabVIEW is Lower level programming that involves customization of user interfaces, peripheral device control, and data manipulation. LabVIEW is the center piece of the National Instruments software that will integrate code from other NI products.
IMAQ is a supplemental package that can be added on to LabVIEW for additional functionality. IMAQ provides LabVIEW with a library of image acquisition functions.
Vision Assistant functions much like LabVIEW itself. The Vision Assistant provides the user with image processing functions which clean/restore/manipulate an image so that it can be handled in LabVIEW or the Vision Builder. Vision Assistant code can be exported so that it can be handled by LabVIEW.
Vision Builder is a complete control/programming module in and of itself. The program interface provides a high level programming design which controls the image acquisition, all the way through the image processing. Vision Builder also contains the Vision Assistant.
Vision Development Module is a combination of the Vision Assistant and the Vision Builder. First off, the module provides LabVIEW with an extensive library that contains many of the image processing functions that is included with Vision Assistant. Secondly, the program also has an embedded Vision Builder program, that gives the user the option of a provided UI, or self developed UI through LabVIEW. The Vision Development Module is a complete package of vision acquisition and processing software.
‎06-15-2006
05:37 PM
- last edited on
‎06-11-2026
09:40 PM
by
Content Cleaner
‎09-28-2006 10:26 AM
Hi system.
I am a student started out my proj which need to use NI Vision builder. I too, face a problem as you. How do it start? There wasnt much tutorials unlike labview, but there are some guide which shows a little on vision. The explaination is good too, as the name/term of software used might be misleading for a beginner. However i had mange to work out a far bit in the builder.
I do face another problem after successfully located the obj in the NI Vision builder, i tried to export to labview. There are many VI files and library file. I need to use the x,y coordinate to do a control. Which VI should i use to get the co ordinate position? Does anyone knows?
‎09-29-2006 01:19 PM
khsay,
I am not sure that I fully understand your question. Do you want to click on an image display and return the coordinates of where you clicked? The more detail you can give me on what you want to do, the better I can help you. Thanks.
Chris
Applications Engineer
‎10-01-2006 08:15 AM
‎10-02-2006 04:03 PM
Hi khsay,
Do you want to share data between VBAI and LabVIEW with they are both running at the same time? This would not be necessary if you build LabVIEW code from a VBAI script. When you build LabVIEW code, it will contain all of the functionality of the VBAI script from which it was built, and you shouldn't have to worry about sharing data between the two programs.
Chris
‎10-08-2006 07:33 AM
‎10-09-2006 01:35 PM
