vision OCR Read
Hello all
I run the example OCR Example.vi and added the new file Image14
But was recognized only one characters from seven on my file.
Where is my error?
Regards
Iskander
File was added.
Message 1 of 8
(4,801 Views)
Iskander,
Have you used the OCR Training Utility to train this tool to recognize your characters? If not, I suggest starting there. You can access this utility in Windows by selecting Start > All Programs > National Instruments > Vision > OCR Training. It is important to run this utility to ensure OCR runs properly.
--Michelle
Message 2 of 8
(4,768 Views)
Michelle
Thanks for the answer
will be learn
Regards
Iskander
Message 3 of 8
(4,712 Views)
Iskander,
This tool "trains" the OCR algorithm to recognize your characters. There is a tutorial you can go through with example images/characters. You can get to the tutorial by opening OCR Training > Help > Tutorial...
--Michelle
Message 4 of 8
(4,697 Views)
Hello Michelle
Thanks for the attention
I found this help
I have the question
How min size in the pixels of the symbol may I recognize ?
Best regards
Iskander
Message 5 of 8
(4,676 Views)
Hi Iskander,
A general rule is to keep your characters between 25 and 40 pixels:
"Character size is the total number of pixels in a character. Generally,
character size should be between 25 and 40 pixels. If characters are too
small, training becomes difficult because of the limited data. The additional
data included with large characters is not helpful in the OCR process, and
the large characters can cause the reading process to become very slow."
I got this information on page 18-11 from the NI Vision Concept Manual (Start > All Programs > National Instruments > Vision > Documentation > NI-Vision). Chapter 18 contains  very detailed information about  how OCR works and is intended to be used.
--Michelle
Message 6 of 8
(4,654 Views)
Hello Michelle
Thanks very much.
You very helped me
Now I am learning the OCR
Best regards
Iskander
Message 7 of 8
(4,635 Views)
You are very welcome!
Good luck with this application and please post back if you have any more questions.
--Michelle
Message 8 of 8
(4,619 Views)
