communicate a cFP-2000 with a serial modem using labview RT
hi, I'm developing an application with a cFP-2000 that have to send or read data from internet using a serial modem RS-232 iR1200 model from nextel that's work with AT commands, I have never used this before, if somebody had some information about how sending data by this means or some examples I will appreciate so much.
thanks for your help.
(2,542 Views)
Hi JosePablo you can use this modems with the fielpoint, to control them you can use the simple Serial comunication Example in LabVIEW>>Help>>Find Examples.
In this link you get more dateails:
Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
(2,465 Views)
