visa
I struggle with a fundamental problem...visa serial read/write.
How do I make a program that both sends data and recieves data via visa serial read/write "at the same time"?
I want it to read data whenever there is incoming data(all the time ready to read) and write whenever
there is something to write(for example a "send command" buttom that user pushes).
I have tested to program in some different ways but I get the same problem(tested program between two PC:s via
hyperterminal)
PROBLEM:
Reading data works fine, it answers on incoming data, but to write data the program´s readfunction
must execute first. The readfunction must take its specified number of bytes before the program
sends the "writebytes". In other words: I cant write anything to hardware unless there is incoming data to read!!
I have tested with one loop containing both read and write. I have tested with two parallell separated
loops with read in one and write in the other.
You can take a look at my attached programexample if you want.
Any suggestions how to solve this?
/thanks fredda
(3,890 Views)
Try attached.
(3,880 Views)
Hi!
Thanks for answer!
I cant open your file, I have LV version 7.0!
Could you send it in my version or..?
/Fred
(3,861 Views)
Hi! Fred,
The attached VI is in LV 7.0 version.
Try and see if you can open it.
(3,854 Views)
Seems like the VI was not attached.
(3,853 Views)
Here is the bitmap of the block diagram.
I am using LV 7.1.
(3,838 Views)
