Closing a labview application.
n Labview 5.1 under Vi Setup, I could select "close afterward if originall closed" for my application. Where is that in Labview 7.1? What I want to do is have the program close if the operator presses an OK button.
(2,974 Views)
It is under vi properties. File >>Vi properties then in vi properties goto the window appearance. Then select customize. It is in the lower left corner. Also you can right click on a subvi in your block diagram and goto subvi node setup. This will allow you to alter the subvi. Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(2,968 Views)
Just to clarify what BJD was saying. If you right click on the SUbVI in the block diagram and set the node, it will only effect that specific instance of the SubVI, not the VI itself.
(2,955 Views)
