visa serial write
i need to connect my electronic hardware/instrument with labview serial visa. i need to enter multiple entries as input like frequencies, data patterns in binaries. but labview serial write accepts only single string as input. pls suggest how should i proceed?
(3,260 Views)
use concanate strings
(3,258 Views)
Hi vinay,
what's wrong with "single string input"?
Strings can be as long as you like them to be.
You can use a loop to process an array of strings.
You can do all you like as LabVIEW is a PROGRAMMING tool!
(3,257 Views)
It really depends on the command format your instrument wants.  Some instruments will let you insert a semicolon between commands and write the one long string.  Others will require separate writes.  I would use a FOR loop in this case (iterate on an array of strings).
(3,227 Views)
