virtual flight gauges
Is there a better way to make virtual flight gauges in LabVIEW? I am looking for virtual cockpit displays such as artifical horizons, heading tapes, horizontal situation indicatiors, and altitude tapes.  I have implemented an artifical horizon in a piecewise, graphical manner in LabVIEW, but this was very cumbersome in a graphical sense.  Does anyone know of a ready-made toolbox of LabVIEW flight instruments?  Has anyone done anything like this?
Thank You
Message 1 of 9
(6,515 Views)
Check out the following posts here and here: -
Radar Control
http://forums.ni.com/ni/board/message?board.id=170&message.id=55431
Artificial Horizon
http://forums.ni.com/ni/board/message?board.id=170&message.id=147927&query.id=38487#M147927
I know there are lots more, just try a bit of data mining in the forum for some more examples (there is a really nice example of some boat controls that I just can't quite put my finger on), but they are all based on the same principles outlined above.
Message 2 of 9
(6,503 Views)
There are activex versions on the web.
http://www.hallogram.com/airinstrumentsactx/
Message 3 of 9
(6,498 Views)
Thank you.  I will give these fligth controls a try.
Message 4 of 9
(6,480 Views)
Thank you. These are exactly the instruments that I seek.  Any advanced lessons in using these Active X graphics with LabVIEW?  Are these supposed to be a plug-and-play operation with LabVIEW?
Message 5 of 9
(6,480 Views)
You can add an activex control to the front panel and select the new gauge types.  You will use property nodes on the block diagram. It takes a bit more work. Hopefully the company documented the controls or it can be a bit difficult.
Message 6 of 9
(6,458 Views)
How can I add such display in front fanel at the place of these such analog gauges as shown in fig belownew1.PNG
Message 7 of 9
(5,419 Views)
You should start your own thread rather than resurrecting multiple threads that are over 10 years old.
(blog)
Message 8 of 9
(5,380 Views)
Yes I checked it. Nothing is given like that in some example they give 3D plotting but nothing like artificial horizon or attitude indicator. Any idea how to design such indicators or threads in labview.
Message 9 of 9
(5,326 Views)
