view graphs
Hallo All,
        I have 5 rakes each having 5 probes, so in total 25 measurements.
Rake 1: PVE_1C1, PVE_1C2, PVE_1C3, PVE_1C4, PVE_1C5
Rake 2: PVE_1J1, PVE_1J2, PVE_1J3, PVE_1J4, PVE_1J5
Rake 3: PVE_1S1, PVE_1S2, PVE_1S3, PVE_1S4, PVE_1S5
Rake 4: PVE_1U1, PVE_1U2, PVE_1U3, PVE_1U4, PVE_1U5
Rake 5: PVE_1X1, PVE_1X2, PVE_1X3, PVE_1X4, PVE_1X5
Through DAQ system the vaues of these measurement names are recieved along with a time stamp. I have plotted the XY graph with x axis as time and y axis as values for each rake. I have control for which rake has to be plotted. When i Change the rake number the graph starts freshly. I wanted the graphs to plot continously and i can switch the view to which ever rake graph i want to see. Please find the images for reference. Thanks in advance.
Hari krishna
Message 1 of 11
(5,492 Views)
Hi Hari,
all we can say from your BD image: You need to change your data buffering and display…
Message 2 of 11
(5,479 Views)
Hallo Mr.GerdW,
        Thanks for the reply. I am very beginner. I would be glad if you can provide an example or screenshot of how to change the buffer and display. Sorry If Iam taking lot of your time. I highly appreciate your help.
Best Regards
Hari krishna
Message 3 of 11
(5,459 Views)
Accepted by harisskriss85_85
Hi Hari,
right now it seems you create a new buffer each time you switch the case.
You need to change it so you store all measurement values in your buffer. The user than just selects, which signals should be displayed in the graph - the signals will be get from the "whole" buffer…
Message 4 of 11
(5,441 Views)
Hallo Mr.GerdW,
       Thanks for the solution
Message 5 of 11
(5,433 Views)
Why not use the build-in plot visisibility property
LV2012 has a bug in the legend , the first plot can not be disabled by a checkbox ....    so another way is shown (that could be improved however it works .....
View Listbox is set to 1 or more Items .....
Greetings from Germany
Henrik
LV since v3.1
Message 6 of 11
(5,414 Views)
Hallo Mr.Henrik,
Thanks for the solution. I think your suggestion was about plots in a graph. My problem was, I had a case structure controlled by an Enum. When I change the case by Enum, the graph starts freshly for the new case.
Message 7 of 11
(5,362 Views)
Hallo Mr.GerdW,
      Suppose i have mutliple graphs (for example 10 XY multi plot graphs). I dont want to see all the graphs at the same time. How can I control viewing of a praticular graph which I want? Thanks for your time
Message 8 of 11
(5,359 Views)
Hi hariss,
you can use
- use the visibility property of the graphs
- put the graphs on different tabs of a tab container and switch between those tabs
- put the graphs in subpanel VIs in a subpanal container
- use only one graph and change the data that is visible in the graph…
Message 9 of 11
(5,354 Views)
Hallo Mr. GerdW,
  Thanks for the instant reply. 2nd option suits me best.
Message 10 of 11
(5,349 Views)
