vi testing with subvis
I've been testing out the unit testing tool that comes with LabVIEW and I can set up and run tests on each unit. Is the tool capable of creating a unit test for every vi in a project in one go? I could then simply modify each test to test the vi it is for. Also, is it possible with this tool to run a test on a vi with subVIs and inject errors or other inputs to the subVIs? Or is it a case of testing each and every vi separately? This makes for a large project.
Tay
(3,244 Views)
Accepted by slipstick
Hi Tay,
You can use Setup and Teardown VIs to test your VIs in this manner.
Refer to the Setup and Teardown VI section in the help manual:  http://zone.ni.com/reference/en-XX/help/372584B-01/lvutfhowto/utfh_config_set_tear/
(3,207 Views)
Well, that was easy. Smiley Happy
(3,173 Views)
Glad I could help!
(3,162 Views)
