.vi's unable to run because of real-time Startup error
See that attached files for the error. Whenever I try and deploy the code onto the robot the attached error comes up. Is there any fix for this or is this a new error? I have also tried a completely new C-Rio project so that it is the basic settings that FIRST gives us. This same error comes up with that one also so I am thinking it is a computer problem on my end.
(2,325 Views)
It sounds like there is a start up application already on the cRIO that has different versions of these VIs as dependencies. I'd recommend turning on the NO APP setting on your cRIO. Depending on which cRIO you have this will either be a hardware switch on the cRIO or a setting you can change in Measurement and Automation Explorer.
Miles G.
Staff Applications Engineering Specialist
(2,275 Views)
