Well done CLD examples
Does anyone know of well done examples that are finished from taking the examples test for the CLD?
Please post links !
Chuck
(3,122 Views)
I suggest you look in the Certification forum.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,118 Views)
Come on folks! there has to be good examples out there !
here is one I think looks pretty good
http://forums.ni.com/t5/Certification/Boiler-CLD-Exam-Example-Critique-amp-Comments-welcome/m-p/2042...
(3,051 Views)
I would honestly start with the 4 examples that NI provides.  https://lumen.ni.com/nicif/us/ekitcldexmprp/content.xhtml  Check there.  I found that the ATM solution, especially, was very helpful and quite elegant in solving the problem.  I looked through that code for hours when preparing for the CLD and found a bunch of helpful tips that I never knew before in LabVIEW (especially the use of string commands). After that, the other link that was posted was extremely helpful as well.
Nathan - Certified LabVIEW Developer
(3,044 Views)
This discussion should really be in the Certification forum. THat may be one reason you are not seeing many responses here.
Mark Yedinak
LabVIEW Champion
(3,029 Views)
Moreover,  you'll learn more by reading critiques of bad CLD examples.  (Not bad bad, just "could improve" like we all can)
"Should be" isn't "Is" -Jay
(2,982 Views)
