version conversion
can someone plaease update these VIs so I can open them in labview 8.5.1?
Message 1 of 12
(5,008 Views)
Here you go.  They are in LV 8.2 which you can open in 8.5
There is a missing subVI.
Also, there was an error message about a CIN calling external code no longer being supported.
Message 2 of 12
(5,001 Views)
i'm sorry but would you also mind converting this one?
Message 3 of 12
(4,995 Views)
Just curious..
Why do you need to convert them from LV8.2 to LV8.5?  You can simply open them.
R
Message 4 of 12
(4,991 Views)
its not conversion from 8.2 its to 8.2 so i can open them, its from 4.0
Message 5 of 12
(4,989 Views)
Here it is in LV8.2.  There was an error message about a missing global variable.
Message 6 of 12
(4,963 Views)
Is it possible to update global variables? the one i need updated is attached if it is possible can someone please convert it? this should be the last conversion.
Message 7 of 12
(4,947 Views)
i had to add an .txt extention in order to upload it, romove the extention to return to normal
Message 8 of 12
(4,944 Views)
I don't know why you would have needed to change the extension to upload it.  What was its extension?  Something besides .vi?
Here it is saved in LV8.2
Message 9 of 12
(4,933 Views)
it acually had no extention
Message 10 of 12
(4,929 Views)
