version conflicts between host labview and RT engine
there is problem that i cannt switch target to feild point. It said that "version conflicts between host labview and RT engine" . But my labview is version 7.0 and the real time module is version 7.0 too. Anyone can give me hand? Thanks
(3,095 Views)
Depending on your version of MAX, you should be able to change the version on the FP (in remote systems). If you can't do it in 3.0, try upgrading to 3.1 (you will have to search for it on the site). If that doesn't work, you can try resetting to factory default and then see if you can do this.
Another tip, which for some reason seems to help, is updating the OS\Run-Time Engine when windows is in safe mode.
Try these and see if they help.
BTW, as a tip for next time, you're more likely to get a good answer for something like this if you post in the FieldPoint board.
___________________
Try to take over the world!
(3,090 Views)
hi,tst
Thanks for your reply.Here is the version of all software:
MAX: 3.1.1 3003
LabVIEW run time engine : 7.1
LabVIEW : 7.1
Field point software : 4.1
I have tried the ways u have suggested,but it still cannt work.
Another problem is that when i click "+software" to view the software installed in the Remote system of MAX, the MAX would go to be frozen. When i right click to install the software, en error is occured that "Unable to loacte the LabVIEW run time engine,LVBrokerAux70 requires a version 7.0rc0( or compatible) LabVIEW Run-time engine.Please contact the vendor of LVBrokerAux70 to correct this problem." Can anyone give me hands to solve this problem? THANKS
(3,068 Views)
Can you follow the steps listed in the following Knowledge Base? http://digital.ni.com/public.nsf/websearch/1b3d6b49e4cd7c8386256fc40060e4e4?opendocument
If not, try formatting the controller by right clicking on the controller's name in MAX under Remote Systems and select Format Disk. Once you have done this, go through the steps in the linked Knowledge Base to install your software.
Let me know if this does not help.
Sean C.
(3,048 Views)
