Explorer Integration Registry Settings
Does someone know what the registry settings are to allow LabVIEW libraries to be viewed in the Windows Explorer, Utilities that are designed to correct bad registry settings have a tendency to view those entries as invalid and remove them.
(2,997 Views)
All you should have to do is go into LabVIEW and in the Options setup, under Miscellanous, uncheck "Enable Windows Explorer for LLB Files", then click OK. Might have to beboot here. Then go back in, recheck it. (reboot) That should reenable it automatically.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,993 Views)
