03-23-2020 03:58 AM
A couple of examples of what i meant and how you can improve.
03-23-2020 04:02 AM
Also, Error in and out should be in lower left and right corner of VI's
03-23-2020 07:12 AM - edited 03-23-2020 07:16 AM
@Yamaeda wrote:
You need to be careful about closing front panels. If you close all of your panels, your application will stop. From this picture, I would say you likely just want to use a Property Node to set the front panel state to "Hidden", run your subVI, and then set the panel state to "Standard".
03-23-2020 07:27 AM
@paul_cardinale wrote:
@Bob_Schor wrote:
When I started learning LabVIEW, I already had several dozen years of programming experience, EW development.
Hmm. If you started programming when you were 10, that would make you between 60 and 80 when you started learning LabVIEW. You've been on this forum for more than a decade, which would put you around 75 - 95 years old now. Maybe you meant to write something else.
This is of course open to the interpretation of "several", but I'm going to guess based on your 75-95 statement that you've perhaps mixed up a dozen (12) and a score (20)?
Several dozen might be ~48 years? Perhaps more achievable than the 80 that the same multiplier would give for 20 per unit.
03-23-2020 08:47 AM
Yes, good point. I mainly to keep the original solution but get rid of the hard coded 'open vi ref' in the callee.
/Y
03-23-2020 12:19 PM
Thanks Bob for taking your time in guiding and providing the resources.It will surely help me
03-23-2020 12:25 PM
what if the information i am getting through the protocol is at bit level. Like 1 byte data i am receiving is having status of 8 solenoid valves (ON/OFF). I have to extract it at bit level to blink the LED in my main window Front Panel. Is their any better way to break it down to bit level?
03-23-2020 12:41 PM
You are receiving data on a "byte level", not "bit level". So for display (and for display only!), you can convert it to a boolean array where you can show all 8 bits as LEDs array indicator. Use a multiline caption to label them. No need to index out individual bits. If the LEDs are not arranged in a row or column, convert to a cluster with arbitrarily arranged LEDs.
03-23-2020 01:40 PM
I find it convenient to convert the array of Booleans to a cluster so you can label them individually. It makes any wires self-documenting.
03-23-2020 01:56 PM
@billko wrote:
@altenbach wrote:
If the LEDs are not arranged in a row or column, convert to a cluster with arbitrarily arranged LEDs.I find it convenient to convert the array of Booleans to a cluster so you can label them individually. It makes any wires self-documenting.
Yes, but converting to a cluster is a bit more work, especially if you want the labels to be "in the wire" to later (un-)bundle by name, etc. If you just wire to an indicator with the correct labels, it's of course easier.
Here's how I typically use the "caption" for a plain vertical boolean array (play with LED size and font size to match things up).
