verification of my software code for best practice
A couple of examples of what i meant and how you can improve.
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 34
(1,827 Views)
Also, Error in and out should be in lower left and right corner of VI's
Qestit Systems
Message 12 of 34
(1,826 Views)
@Yamaeda wrote:
You need to be careful about closing front panels.  If you close all of your panels, your application will stop.  From this picture, I would say you likely just want to use a Property Node to set the front panel state to "Hidden", run your subVI, and then set the panel state to "Standard".
Message 13 of 34
(1,810 Views)
@paul_cardinale wrote:
@Bob_Schor wrote:
When I started learning LabVIEW, I already had several dozen years of programming experience, EW development.
Hmm.  If you started programming when you were 10, that would make you between 60 and 80 when you started learning LabVIEW.  You've been on this forum for more than a decade, which would put you around  75 - 95 years old now.  Maybe you meant to write something else.
This is of course open to the interpretation of "several", but I'm going to guess based on your 75-95 statement that you've perhaps mixed up a dozen (12) and a score (20)?
Several dozen might be ~48 years? Perhaps more achievable than the 80 that the same multiplier would give for 20 per unit.
GCentral
Message 14 of 34
(1,802 Views)
 Yes, good point. I mainly to keep the original solution but get rid of the hard coded 'open vi ref' in the callee.
/Y
Qestit Systems
Message 15 of 34
(1,790 Views)
Thanks Bob for taking your time in guiding and providing the resources.It will surely help me
Message 16 of 34
(1,756 Views)
what if the information i am getting through the protocol is at bit level. Like 1 byte data i am receiving is having status of 8 solenoid valves (ON/OFF). I have to extract it at bit level to blink the LED in my main window Front Panel. Is their any better way to break it down to bit level?
Message 17 of 34
(1,756 Views)
You are receiving data on a "byte level", not "bit level". So for display (and for display only!), you can convert it to a boolean array where you can show all 8 bits as LEDs array indicator. Use a multiline caption to label them. No need to index out individual bits. If the LEDs are not arranged in a row or column, convert to a cluster with arbitrarily arranged LEDs.
Message 18 of 34
(1,753 Views)
I find it convenient to convert the array of Booleans to a cluster so you can label them individually.  It makes any wires self-documenting.
Bill
CLD
(Mid-Level minion.)
Message 19 of 34
(1,739 Views)
Yes, but converting to a cluster is a bit more work, especially if you want the labels to be "in the wire" to later (un-)bundle by name, etc. If you just wire to an indicator with the correct labels, it's of course easier.
Here's how I typically use the "caption" for a plain vertical boolean array (play with LED size and font size to match things up).
Message 20 of 34
(1,733 Views)
