11-14-2007 12:36 PM
11-14-2007 12:47 PM - edited 11-14-2007 12:48 PM
11-14-2007 01:13 PM
I like the way this works but but the clusters may not all be the same. When I changed one of the clusters it doesn't work because the type changes. But you did point me in the right direction. I simply use the cluster element to type the variant. Seems to work fine. Thanks Ton.
