variant in event structure
I have a very large user interface that uses tabs and I need to clean it up a bit. I have been playing with registered events > controls on page > value change. I really like the simplicity of it, but I can't seem to get the data type correctly from the variant NewVal terminal. I've tried just about everything I can think of. Attached is an example of what I am trying to do.
PaulG.
Retired
(3,593 Views)
Since all the cluster elements are the same you can use the following code:
I added a case for 'Cluster 1' and 'Cluster 2'
Change to your needs
Ton
Message Edited by TonP on 11-14-2007 07:47 PM
Message Edited by TonP on 11-14-2007 07:48 PM
My LabVIEW Ideas
(3,587 Views)
I like the way this works but but the clusters may not all be the same. When I changed one of the clusters it doesn't work because the type changes. But you did point me in the right direction. I simply use the cluster element to type the variant. Seems to work fine. Thanks Ton.
PaulG.
Retired
(3,575 Views)
