There are three peak samples in the Find examples when you search for peak. From the block diagram in the analyze, signal processing, time domain, threshold peak detector.vi and peak detector.vi.
Also in analyze, waveform monitoring, waveform peak detection.vi
Also in analyze, point by point, time domain ptbypt, peak detector ptbypt.vi and threshold peak detector ptbypt.vi
These vi's skew the actual location of the peak by a small amount from the actual x axis datapoints. If you need the exact x axis location, take the locations from the peak detection and split the original data then use the min/max array vi.
