value from Vi into SubVI
Hallo
I need a help , I want to put the result from VI into SubVI , can someone explain me  how
i start to do it but I didn't know how to finish it
Thank you in advance
Toni
Message 1 of 8
(3,486 Views)
Hi dctoni,
create a control of the type you want send to the subvi, in the subvi. right click on the icon and select "conector pane" (only possible in the FP), add the created control to the conector pane. save your vi. Now you can conect the value to transfer to the subvi.
Mike
Message Edited by MikeS81 on 04-07-2008 04:10 PM
Message 2 of 8
(3,482 Views)
In the subVI, create a front panel numeric control and wire it to your Format Into String. From the subVI's front panel, conect this new control to the subVI's connector pane. Click the subVI's icon and select Show Connector.  The prperty node and reference in the subVI are not needed. After you save the subVI, go back to your main program. On the block diagram you will have to right click on the subVI and select 'Relink to SubVI. After you have done that, you can just wire your result to the subVI.
This is very basic LabVIEW. You really need to look at the resources for learning LabVIEW at http://www.ni.com/academic/lv_training/how_learn_lv.htm
Message 3 of 8
(3,476 Views)
thanks guys for your reply
I have been reading this the whole day , and I still don't know how , coz i am using a german version and it is not easy to follow everything , but i will try again maybe with this description I will know how
thanks again
Message 4 of 8
(3,471 Views)
Here's the modified subVI.
Message 5 of 8
(3,461 Views)
OK
but what do you mean with "connect this new control to SubVI's connector pane " and where can i find it
Message 6 of 8
(3,450 Views)
Dennis thanks man I understand it  . HaliluyaSmiley Very Happy
Message 7 of 8
(3,447 Views)
Hello dctoni,
thank you for using the NI discussions forum. I agree very much with Dennis' comment about taking a trainings class for LabVIEW, especially after reading this comment from you:
"I have been reading this the whole day , and I still don't know how"
Please have a look at this link that provides all the localized information about LabVIEW trainings classes at NI-Germany. This will help you to save time and money and to become more successful with LabVIEW. For the case that you are working on a thesis, please contact NI-Germany as we offer special conditions for students.
Thanks and best regards,
Jochen Klier
Message 8 of 8
(3,407 Views)
