using shared variables in windows 7 64 bit
Hi !
I am trying to use network published shared variables (with Labview 8.6.1) in windows 7 64 bit. I have three PCs on the network. All PC's are visible to each other. I am able to remotely log on to other PCs.
But when i run my program, the shared variables are not able to read the value over the network. The same program was working with windows XP.
I am not sure whether it is windows issue or labview issue.
Please help ASAP.
Mandar Joshi
(2,554 Views)
I am having the same problem with Shared Variables with LV8.6.1 and Win7 64 in a program that uses a shared variables to share in seperate loops. I was able to use a local variable instead, but would love to know if it possible to use shared variables with 8.6.1 and win7.
(2,494 Views)
