using cursors on 3D plot
Hello!
I'm using 3D plot block. I've inserted a cursor,each point of the plot has a name i want that the cursor show this name.
I've seen that the cursor of 3D plot shows you the coordinates of the point. How i can catch the value of the cursor...in 2D plot i use property node to obtain this value, but i have no idea if it is possible.
I need this information strongly.
Thanks!
(3,334 Views)
The 3D cursor name can be accessed using a property node, in a way very similar to thre 2D cursor. Except that it is more difficult to access the proper property node. The attached vi shows how to do it.
Chilly Charly    (aka CC)
(3,319 Views)
Hello!
Please, can you post again the attachment in Labview 7.0 version? I can't open the file because is a higher version.
Thank you very much!
(3,303 Views)
Here it is...
(3,301 Views)
First of all thanks for your fastness.
I try to open this file and appears a window which says:
cw3dgrph
Error loading control. A newer version needed. The default settings for the control will be used.
It's possible that Labview 7.0 haven't got the controls you use? The controls of Labview 7.0 about 3D plot allows you modify cursors information,....
In other way, can I install this newer controls of 3D in Labview 7.0
Thanks again
(3,291 Views)
I don't have the same problem when loading the file from the forum to my LV 7.0. Something may be corrupted on your side. Just to be sure, try again with the attached vi...
(3,287 Views)
