Problem: DLL using fclose doesn't close file unless exit Labview completly
Do I have more than one option to do this correctly? I do not want to be forced to stop and start
my Labview application every time I want to close a file.
    Thank you,
    Christopher Lusardi
Message 1 of 15
(4,533 Views)
Hi Christopher,
Can you exand on your question a little?
Are you calling a DLL from LabView, via Call Function Node?
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
Message 2 of 15
(4,505 Views)
LabView is calling the DLL from a Call Function Node.
The DLL is a copy of the below code. Is there anything wrong with this code?
Christopher Lusardi
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
char file [100];
#include "my_header.h"
int create_file ()
  char Location [100] = "my_files/";
  FILE *Fptr;
  char box [50];
  int numalo = 0;
  int numdalo = 0;
  int mypid;
  int element;
  if ( gethostname (box, 50) < 0 )
    printf ("gethostname failed\n");
    return (-1);
  mypid = (int)getpid ();
  sprintf (file,"%s%s_%d",Location,box,m­ypid);
  if ( (Fptr = fopen (file,"w+")) == NULL )
    printf ("fopen () failed opening file = %s\n",file);
    return (-1);
  else
    fprinttf (Fptr,"%d\n",Number_of_items);
    fprinttf (Fptr,"^^^^^^^^^^^^^^^^^^^^^^^­^^^\n");
    for (element = 0; element < Number_of_items;element++)
      if ( vegetable [element] == 1024 )
        fprintf (Fptr,"%d %d %X %d %d %X %X %X\n",
          vegetable [element],
          fruit,
          filtered_water.tomato [element],
          filtered_water.green [element],
          filtered_water.bacteria [element],
          filtered_water.organic [element],
          filtered_water.raw [element],
          filtered_water.washed [element]);
      else
        fprintf (Fptr,"%d %d %X %d %d %d %X %X\n",
          fruit,
  fclose (Fptr);
  return (0);
Message 3 of 15
(4,494 Views)
Hi Chistopher,
Where is Number_Of_Items being initialised?
Message 4 of 15
(4,495 Views)
Number_Of_Items is incremented/decremented based on type of request asked of a service program.
This service routine is a separate program. Many applications, running at the same speed, make the requests.
If a resource is asked for the variable is incremented. If the resource is given up it is decremented.
There are about ~20 * 2 (really copies of the 1st 20) plus the DDL's routines used to accomplish this task,
and a large prototype routine that does the same thing. Each different routine is for a different type of request.
Christopher Lusardi
Message 5 of 15
(4,488 Views)
The above code segment is a typo. It should be:
 fprintf (Fptr,"%d\n",Number_of_items);
 fprintf (Fptr,"^^^^^^^^^^^^^^^^^^^^^^^­^^^\n");
Christopher Lusardi
Message 6 of 15
(4,476 Views)
Where is Number_of_items defined?  is it a static?
Message 7 of 15
(4,474 Views)
It is initially defined in a dot h file for the main routine as
int Number_of_items;
and is accessed by including in many files (via another dot h file)
extern int Number_of_items;
It is set to 0 in a file that all users should use at the start of their main routines.
Christopher Lusardi
Message 8 of 15
(4,457 Views)
O'kay, I was told that a GUI button was causing the problem. I investigated and was able to duplicate the problem
outside of the LabView environment. This means that the problem is not a DLL problem, and it is not a LabView problem.
Consequently, the problem is easier to solve, and I can do it on my own. I do not even think it is a fclose () problem.
Thank you for your mis-placed time,
Christopher Lusardi
Message 9 of 15
(4,448 Views)
Hello again,
   I would like to reactivate this problem.
  The problem is I have to exit LabView completely and rerun the application to create a file if I use fp = fopen (...,"w+") as in earlier
posted code. If I do not restart LabView but I delete the file then on subsequent calls to fopen the file will not be created.
  What can I do to prevent exiting LabView but re-create the file on all calls to fopen or something like it?
 Thank you,
 Christopher Lusardi
Message 10 of 15
(4,410 Views)
