using a<x<b in formula node
Hi, I am trying to use the following code snipped in formula node:
 z=(x-2.5)*50;
if (z>-10.0||z< 10.0) {
y = 0;
c=0;}
else {
y = 5*x-12.5;
c=1;}
x is input (from cRIO) and z, y, c are outputs .
It doesn't seems to work properly, y, c are always 0.
How else can I use compound evaluation: -10<z<10 ????
Arthur
(2,863 Views)
Accepted by topic author millerman
replace || with &&
_________________________________________________________________________________________________
LV 8.2 at Windows & Linux
(2,855 Views)
elementary, Watson.
(2,836 Views)
