using a current transducer to measure the current with 0 to 5V output using a data acquisition module to connect to labview through modbus tcp/ip
Hi
I would like to ask how to do convert from decimal readings (data collected from data acquisition module to labview modbus) to rms current readings on labview? I am using a current transducer, CR5410-20 to measure the current. The input and output of this current transducer is 0 to 20A instantaneous and 0 to 5V respectively. I need to find the rms value of the current.
2019-11-14(1).PNG is front panel.
2019-11-14(2).PNG is block diagram.
Thank you.
(2,888 Views)
Accepted by topic author ace2light
Probably with the "RMS.vi" or the "RMS PtByPt.vi".
(2,855 Views)
See my solution to a similar question here
=== Engineer Ambiguously ===
(2,828 Views)
